brcacti
Dec 14 2019, 11:31 PM
I received my crane elec. ignition system and will deal with it this fall. OPINIONS wanted on the upgrade for fuse box, should I also buy that? How important do you all think it is to upgrade the fuse box???
porschetub
Dec 14 2019, 11:49 PM
Won't be any advantage unless you like the shitty stoneage stock setup ,it won't fix any issues but will help with new contacts and modern fuses.
J West is the one I have,cheers.
rjames
Dec 15 2019, 12:33 AM
I have a jwest fb that I bought 12 years ago when I bought the car. It’s still sitting in a box as I haven’t had a need to install it yet.
If it ain’t broke...
914Sixer
Dec 15 2019, 06:18 AM
Clean the contacts, replace the fuses and get a new cover.
Coondog
Dec 15 2019, 07:58 AM
bbrock
Dec 15 2019, 09:24 AM
QUOTE(914Sixer @ Dec 15 2019, 05:18 AM)
I've never seen the problem with the original fuse box as long as contacts are clean and a good cover is in place.
Dec 15 2019, 09:47 AM
My favorite way to handle this is to have a spare panel, clean it with vinegar and then switch it in, wire by wire, to the cars fuse panel. Takes about 10 minutes.
Spend a couple dollars for new fuses and throw the old ones in a little bag in your glove compartment for when your 914 friends need a spare.
