Putting the finishing touches on the Tangerine Racing remote oil cooler set up. It's a tight fit but what a great design. The fan/thermostat requires a switched power source. Draws 5 amps when running continuously.
Any ideas for power ?? Can I splice out the lead for the fuel pump ?? I run carbs and have the Carter rotary pump located forward. Heavy gauge wire to that location to help with loss. Any other locations a possibility ??
Thanks all
