Full Version: Throttle to Plenum seal
PCH
When placing a new throttle body to plenum gasket, do you put some sort of sealer (like Formagasket) on the gasket?
The previous gasket had a sealer on it.
Thank you for your help.
Peter
rjames
QUOTE(PCH @ Dec 23 2019, 12:27 PM) *
When placing a new throttle body to plenum gasket, due you put some sort of sealer (like Formagasket) on the gasket?
Peter
You shouldn’t need it if the surfaces of the TB and plenum are super clean. Torque down the bolts each a little at a time.
rjames
Double post
DRPHIL914
Common spot for vac leak, there is a gasket that should be placed between there at least I have always had one on my 2.0 D-jet
iankarr
A thin smear (thin!) of The Right Stuff can’t hurt.
rjames
QUOTE(DRPHIL914 @ Dec 23 2019, 07:37 PM) *
Gasket yes. Goop isn’t needed if surfaces are properly prepped.
DRPHIL914
QUOTE(rjames @ Dec 24 2019, 12:16 AM) *
headbang.gif Sorry, it was late and I was not reading clearly the OP, lol but I agree o goop needed just gasket-
PCH
Thanks everyone for your help!
