I can't seem to find a part on this car that was left unmolested.
In need of new Ignition key parts. Will consider individual parts only if it comes to that but would prefer a complete key cylinder and column lock assembly (unmolested) with a OEM key if at all possible. Will pay fair price.
Ignition key has always been flaky from the day I bought this car.
Disassembly shows why.
1) Key is not orginal - only God knows how many re-cuts this is. This key does fit the Doors, and rear trunk though and works well with those lock cylinders
2) Ignition cylinder shows many signs of prior owner attacks both exterior and interior. Vice Grip marks as always a giveaway that someone had no idea how to properly disassemble these.
3) lock cylinder wafers don't sit flush to cylinder anymore - either worn or not fitted properly at previous attack.
4) Non-OEM key is too long and hits the roll pin.
5) the hole that the roll pin goes though was previously re-drilled off-axis. Probably as some means to try to fix #4 problem?
6) the bezel that the cylinder rotates in has notches work into it from the wafers not stitting flush and then hanging up as the key was turned.
7) random bits of key and/or lock metal shavings clogging things up from years of wear and abuse.
