QUOTE(xsurfer @ Dec 30 2019, 06:54 AM)
I'm investigating painting my car, 71 stock six. 80k original miles
been in garage for 12 years or so. (I forgot when I bought it)
Looking for painter in So. Ca. Please comment on the value of
paint. I have no clue for cost of 914 paint.
It is going to depend on how much of the car you want painted (engine out, jambs, inside of trunks, etc), how much body work, correction of old body work, and rust repair is needed (ALL need at least some...usually more than you think), How much disassembly is required and how much you can do yourself, If the car needs to be stripped of old failing paint first, the number of primer coats (I recommend 2...block, body work and rust repair, primer, block, final body work, primer, block, sealer, color) type of paint (metallic, base/clear, single stage).
I paint my cars myself and have never spent under $1,500 for materials (sandpaper, masking supplies, filler, primer, sealer, color, clear, reducers, hardners). A quality complete paint job on a 914 with minimal rust repair and body work needed would take me about 200 hours. Shop rates are generally $100/hour.
With a good paint job you will find you need to have your chrome and other trim redone or it will look like heck against the new paint...even if it looks great now.
You can go cheaper, but the first time you park next to a car with a nice paint job you'll be sorry.
