Small car mount modified for early bar, also have the bulk head piece but mount on firewall would have to be fabricated.
What you have is mounts that install on the -4 mounts on the side of the engine compartment. They mount to an early 914-4 crossbar. You supply this mount, as I think shipping might be a tad to much. The small car mount then sets onto of the bar. And then the MT5 rear mounts. All built with isolation mounts from Energy suspension.
New OBX MT5 limited slip diff for a Subaru MT5 - unit has been fully gone through all metal flashing removed in the diff. Screws, washers, and thrust surface washers replaced with hardened materials.
Extra set of the hardened washers, screws and thrust washers. $10 shipped. Not sure why I have an extra set
Subaru Gears 108mm axle flanges for the MT5. New, only installed for mocking up, new Subaru pins for the flanges.
Gates Green Stripe Hose enough to go front to back on a 914 chassis. Return line is 1-1/4 the hot side is 1"
