Snebs2
Jan 14 2020, 09:57 PM
Can someone send me a picture of how this goes back together. Just the The aluminum seal the fuzzy and the rubber part. I cannot make heads or tails from the diagram online.
Click to view attachment Click to view attachment Click to view attachment
Mikey914
Jan 15 2020, 01:07 AM
The fuzzey with the metal back goes into the larger aluminum channel The bulb from the other scraper goes into the C shape at the top to hold the rubber against the glass.
This shows the fuzzey strip with metal installed
close up but you get the idea
Mikey914
Jan 15 2020, 01:08 AM
To locate the screw holes, put the fuzzey in the aluminum track and drill from the back side through the holes into the fuzzey. You can put int a screw to set, trim the end, and install.
Mikey914
Jan 15 2020, 01:11 AM
hard to see from the 1st pic which outer you have, But here is mine with the early scraper installed on that late door (end cap gives it away).
The outer scrapes go on after the window is assembled.
Snebs2
Jan 15 2020, 07:26 PM
Thank you for your pictures and your insight that is what I needed I am back on track at least with the doors...lol
Mikey914
Jan 16 2020, 01:39 AM
No problem, the doors can get a little hard. Especially if you try to install out of sequence.
