Adjunct to previous postings:
I put a 1 kOhm potentiometer (electrical resistance) between the old TS2 and its connector; turned it to about 0.3 kOhm (300 Ohm). A 0.2 kOhm value was still too low in MPO.
This dramatically improved engine performance; cold and hot starting is better, idle is definitely more regular, and acceleration has improved. What it will do to gas mileage I can only guess...
Still curious to what a new TS2 will do, but it hasn't arrived yet. I found out that TS2 has a so called NTC or negative temperature coefficient and wears over time so that resistance will decrease.
