Miguel K R
Jan 16 2020, 04:35 AM
Hello,
I just received from Germany a pair of Front Struts that were advertised as Bilstein G modell.
I guess that the G modell was used on '74 and later cars, it has 90mm (approx. 3.5") between the fixing points for the brake calipers, and 18mm thread.
However, the struts I received have 75mm (3") between the center of the fixing points for the calipers, and a thread of 16mm diameter, so I assumed these were F modell used on 911 cars till '73.
Looking at the struts more in detail I found that the steering arm is engraved with the number 12, followed by the VW logo.
I guess that VW never produced struts for the 911, and probably this is a strut for a 914-4 (useless for me, as I was buying the struts to convert my 914-4 to 5 lug wheels).
Can someone help clarifying this,to help me to convince the German supplier that he has to accept the return of the struts.
Thanks in advance
Miguel K R
(Portugal - Europe)
914Sixer
Jan 16 2020, 06:52 AM
Going to have to have pictures to see what you have. Sounds like they sent you 914-4 struts. VW logo should not be on Porsche struts. VW struts will have a straight arm to hook to steering rack and 911 will have curved arm.
falcor75
Jan 16 2020, 07:58 AM
A five bolt strut should look like this, although mine does have the 75 mm (3 inch) bolt spacing for the brake calipers.
Miguel K R
Jan 17 2020, 04:01 PM
[quote name='falcor75' date='Jan 16 2020, 01:58 PM' post='2777967']
Thanks a lot for the explanation which was the final argument to convince the supplier to accept the return of the struts, which did not correspond at all to the advertisement :
- they were not Porsche 911 (the steering arm was straight instead of curved)
- they were not G model (they were for 3” calipers instead of 3.5”, and had 16mm thread instead of 18mm)
- they were not Bilstein
I wonder why Porsche used the straight and the curved steering arms.
And when switching to 911 struts to convert to 5 lug, we simply use the 914-4 tie-rods ?
914Sixer
Jan 18 2020, 07:17 AM
Tie rods are all the same.
