QUOTE(gulf908 @ Jan 16 2020, 08:15 PM)
many thanks guys
sometimes its hard to picture how this works from the parts cd
a further thought I had is to replace the ribbed drain pipes from the air box with some smooth plastic pipes
anyone done this ?
to my eyes,all the ribs do is to help accumulate leaves and debris and eventually clog the pipes - thoughts ?
cheers
Dennis
Even without the grill, I never had any problems with debris in the drain pipes. With the grill, I really don't see it being a problem. The drain pipes need to be flexible though to make the bends which is where the ribs help. Be careful taking the drain tubes off though because the nipples on the air box are not terribly hard to break off. If you look at the left side nipple on the pic I posted, you can see the gray JB Weld I used to reattach mine after it broke. Seems to be a solid repair and was easy to do, but would have been better to not break it in the first place.
