RKramden
Jan 20 2020, 02:17 PM
This is my first time starting a topic, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet and fuel pump. The pump starts with the ignition switch, Pump also runs when Air sensor arm is manually moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, the car starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem.
ndfrigi
Jan 20 2020, 02:35 PM
do you mind also sharing pic of your car and engine? try checking also fuel lines below the fuel tank, maybe the rubber kink. you borrow fuel pressure test kit from local store and try checking of fuel flow and pressure. what city are you?
RKramden
Jan 20 2020, 03:04 PM
QUOTE(ndfrigi @ Jan 20 2020, 03:35 PM)
Too embarrassed to show any pix just yet. Stripped the wiring harness wrap off of the EFI harness looking for shorts, so imagine a pile of rust with a bunch of loose wires on top. Fuel flow seems fine as it will run when I unplug the air sensor. The car currently in intensive care in Long Beach CA.
ClayPerrine
Jan 21 2020, 01:56 PM
Check where the engine harness plugs into the relay board. There should be a yellow wire with a spade connector that is separate from the 12 pin plug. That wire should hook to one of the two rear pins on the 4 pin connector located in the left rear of the relay board. Without that wire, the fuel pump won't receive power when cranking.
Clay
RKramden
Jan 21 2020, 02:12 PM
I will check this evening, but I am getting fuel when cranking. If I load it up a little it will start, but it will die when that fuel runs out. With the ignition on, I can move the air flapper and hear the pump run as well. Something appears to be happening between initial start and air sensor opening that is not letting the fuel pump switch over voltage to occur.
ClayPerrine
Jan 21 2020, 02:19 PM
QUOTE(RKramden @ Jan 21 2020, 02:12 PM)
Are all the vacuum hoses hooked up per the vacuum diagram? If you have an air leak, especially between the air flow meter and the throttle body, an L-Jet car won't run.
Also, check to see if the big black hose between the air flow meter and the throttle body is split. They are prone to doing that between the folds, and it is hard to see it. Symptoms will be that the car will try to start and immediately die when the engine moves ln the chassis, causing the split to open up.
Clay
ClayPerrine
Jan 21 2020, 02:20 PM
QUOTE(ClayPerrine @ Jan 21 2020, 02:19 PM)
Clay
Also, replace the oil cap seals. They will cause it to run badly or not at all.
RKramden
Jan 21 2020, 03:11 PM
thanks Clay, I will check all those things tonight. Big hose to Throttle body absolutly has holes. I have temporarily taped it up with a new one on order. I think I have the oil cap seal in the box of other stuff I have previously bought. All other vacuum hoses are new silicone but I will double check routing. What is puzzling me is that when I unplug the Air Flow Sensor, the car starts and stays running.
jcd914
Jan 21 2020, 03:28 PM
QUOTE(RKramden @ Jan 21 2020, 01:11 PM)
There is a switch inside the Air Flow Sensor that until the flap moves the pump won't run. Disconnecting the Air Flow Sensor eliminates this fuel pump switch and the pump runs when the engine cranks over or the ECU sees an ignition pulse.
It sound like the flap in the Air Flow Sensor does not move enough while cranking to close and allow the ECU to turn on the fuel pump.
Jim
dr914@autoatlanta.com
Jan 21 2020, 03:44 PM
with the key on and when you move the arm under the black plastic air flow meter top, the dual relay will click and the fuel pump will run. also when you crank the car and observe the air flow meter pointer, it will wiggle back and forth coming off the small set of points and letting the fuel pump run. If the flap/pointer does not move you have a massive air leak, could be the ribbed intake boot loose or with a crack.
QUOTE(RKramden @ Jan 20 2020, 01:17 PM)
porschetub
Jan 21 2020, 03:47 PM
QUOTE(RKramden @ Jan 21 2020, 09:17 AM)
My understanding was that the pump only gets power from ignition switch and won't start until the AFM air gate moves off the cut off switch,this should happen when the engine is cranking before starting.
I think the switch is to stop the pump on throttle overrun,in the later L-jet version (bus) the ecu controls that function so they use a different AFM.
When you say the car runs when you disconnect the air sensor ?do you mean the AFM? if so I can't see how it would run with the plug off.
Whats the condition of the wiper board inside the AFM ?,if the wipers have bad contact it can cause the issue you have,can be cleaned or reset if tracks are worn.
Good luck.
ndfrigi
Jan 21 2020, 05:04 PM
@rkramden I have spare AFM for Ljet, if you are around Stanton (anaheim/buena park) you can come and use my AFM to test it on your car.
ClayPerrine
Jan 22 2020, 08:29 AM
QUOTE(porschetub @ Jan 21 2020, 03:47 PM)
Good luck.
The fuel pump will run when cranking via the wire from the relay board to the double relay. There is not enough air flow during cranking to open the flap. Once it is running, the air going into the AFM causes the fuel pump contacts to close.
And, any air leak between the AFM and the throttle body will cause it not to run. The air bypasses the AFM, and goes directly into the throttle body. That keeps the AFM from opening enough to keep the engine running.
Definitely replace the big tube between the AFM and the throttle body. Then report back on how it runs.
FYI.. My wife has an L-Jet injected 914. I was trained by VW to work on the L-Jet systems in the 80s. And I have been keeping my wife's 914 alive for 34 years now.
RKramden
Jan 22 2020, 11:11 AM
Thanks All!!
So I checked the Vac lines, all to the right spot and all new
Large intake rubber hose taped up temp for now. New one coming
Unplugged AFM or Air Flow Sensor (they seem to be used synonymously) and the engine will start and idle. The flapper moves freely and the pump contact closes when engine starts.
If I give it gas it will quit. Seems logical as the ECU is looking for an air signal, assume it will idle without one.
If I plug it in, it quits. My feeble mind thinks that maybe the fuel pump has been hotwired to bypass the AFM/Dual relay signal and somehow sending that signal is grounding out the fuel pump. As previously noted the PO had bent the arm in the AFM so that it would never make contact (I have bent it back to norm).
I will try to trace the fuel power this evening.
Could someone confirm that the ECU is out of the picture as far as fuel pump power goes? In the line diagrams I have seen, it looks like pump power is either Ignition switch to Dual Relay to pump, or AFM pump relay to dual relay to pump. Input #20 to the ECU looks to be monitoring the pump relay, but I am not sure what it is doing with that input.
thanks again.
ClayPerrine
Jan 22 2020, 12:36 PM
Try these tests:
1. Disconnect the Yellow wire on the starter. Then turn the key to the start position. Does the fuel pump run when you do this?
2. Disconnect the big rubber hose between the air flow meter and the throttle body. Make sure the air flow meter is plugged in. Turn the key on. Open the air flow meter with your finger. Does the fuel pump run?
Clay
RKramden
Jan 22 2020, 01:24 PM
QUOTE(ClayPerrine @ Jan 22 2020, 01:36 PM)
Try these tests:
Clay
#1 pump will run in this scenario.
#2 I can turn the flapper from the top of the AFM with the cap off. The fuel pump will run.
ClayPerrine
Jan 22 2020, 02:16 PM
QUOTE(RKramden @ Jan 22 2020, 01:24 PM)
Try these tests:
Clay
Then the double relay is working as expected. Start by fixing the false air problem (the split hose between the throttle body and the AFM). If that doesn't fix it, then the AFM is probably bad.
RKramden
Jan 23 2020, 10:12 AM
QUOTE(ClayPerrine @ Jan 22 2020, 03:16 PM)
Try these tests:
Clay
Clay, I am leaning towards the AFM as the issue as well, I will try another one once the new hose arrives. Do you have any idea why the car and pump will stay running with the AFM unplugged? Last night I got the RPMs up by slowly increasing the throttle. If I punched it, it would die.....this is all with the AFM unplugged!
ClayPerrine
Jan 23 2020, 03:10 PM
QUOTE(RKramden @ Jan 23 2020, 10:12 AM)
That is a sorta "limp mode" function. If the AFM dies, the L-Jet sees the ignition pulse that is over a certain RPM and will keep the engine running. Without a AFM signal, it will just barely run. Good for getting the car off the street into a parking lot, and not much more than that. It only knows how to make the car idle, nothing more.
RKramden
Jan 23 2020, 05:02 PM
Interesting......just makes it harder for us novices to try to trouble shoot.
Picking up a loaner AFM this evening
ndfrigi
Jan 23 2020, 07:51 PM
QUOTE(RKramden @ Jan 23 2020, 03:02 PM)
Sorry again David that my AFM has 7 pins compare to your 6 pins. Hope you can find one with 6 pins or hoping also it’s not the AFM that you need.
RKramden
Jan 24 2020, 11:41 AM
I will check ohms on AFM this weekend. If they don't check out, off to Pelican for a rebuild. If they do check out does that mean it's good or could there still be an issue with the signal when running? If it is good am I down to the ECU?...ouch!
ClayPerrine
Jan 24 2020, 01:55 PM
QUOTE(RKramden @ Jan 24 2020, 11:41 AM)
The ECUs rarely fail. It is either the L-Jet harness or the AFM. Maybe someone close to you has one you can use for testing.
I recently sold one to
@Rob-O . He was having drivability issues, and the replacement AFM fixed it.
RKramden
Jan 24 2020, 03:12 PM
I continuity tested all the wires from the ECU and they checked out
If there is someone out there with one to loan, that would be great, otherwise $260 from Pelican isn't the end of the world.
Rob-O
Jan 24 2020, 09:57 PM
QUOTE(ClayPerrine @ Jan 24 2020, 11:55 AM)
Absolutely helped clear up some serious drivability issues.
porschetub
Jan 25 2020, 02:02 PM
Are the wiper boards still being made by anybody ?,I seem to remember 914rubber had them but they were D-jet ones or are they the same?.
I noticed Fuel Injection Corp have L-jet AFM's rebuilt on ebay for $199 .
Rob-O
Jan 25 2020, 04:02 PM
The only ‘wiper boards’ I know of that we’re being reproduced we’re those that go in the throttle bodies.
In a 1.7/2.0 D-Jet, that TB board is used to tell the ECU the load on the engine...or more simply, what position the TB is at. On the L-Jet, that board inside the AFM. The ‘wiper board’ on the L-Jet TB is only used to tell the ECU when it is at wide open throttle. None of the boards are interchangeable to my knowledge.
Rob-O
Jan 25 2020, 04:12 PM
Forgot to add, I looked at Fuel Injection Corp’s offerings. I don’t believe that they replace that board. I think their work includes cleaning the board, checking wire continuity, checking the ‘barn door’ flap for binding, adjusting the tension and position of the wiper arm. essentially bringing the unit back to factory specs.
There is a document floating around the ‘Net (itinerant air cooled.net maybe???) where someone explains the adjustments. I’d take that information with a grain of salt. But the document helps explain what the AFM does and how it works.
Even if you go the rebuilt unit from FIC, you might want to use a portable O2 sensor to have the air bypass set correctly for your engine.
Rob-O
Jan 25 2020, 04:25 PM
BTW, you’re welcome to my old AFM. It had been rebuilt and subsequently fiddled with by a PO. There is a decent shudder around 3000rpms but it should work fine for isolating your issue. Heck you could probably run it for a bit until you can get yours repaired/replaced. Just PM your address.
After reading the rest of this thread, I’d agree with Clay. AFM or the harness.
RKramden
Jan 27 2020, 08:29 AM
SUCCESS---kind of
Ohm tested the AFM and was 290 between 6 & 9, and 170 Between 7 & 8 and 36 and 39 were infinite when closed and 0 when open....all per spec. Decided to check these same readings at the ECU plug and found the same (with the AFM plugged in) except between 7 & 8 when sometimes I would get an infinite reading. Started jiggling those two wires all the time watching the reading change from infinity to 170 (note that I had previously stripped the plastic sheathing off of the ECU wiring harness looking for possible breaks a while ago). Worked my way back to the AFM plug where the problem seemed to be coming from. I removed the rubber surround on the plug and found that I could move #7 in and out ever so slightly, and make the Ohms switch. I cut the plug off and crimped new individual connectors on, and viola!....It started and stayed on with all wires connected! Now it wants to die when I punch it, but I can get the RPMS up by feathering the peddle. I will replace the rubber hose between the AFM and the throttle body that just arrived and check for any other leaks......Any other suggestions?......how much tension or slack should there be in the throttle cable at the TB connection?
ClayPerrine
Jan 27 2020, 08:46 AM
Now you know the harness is bad, so I suggest getting a Bowlsby replacement.
Bowlsby Wiring HarnessesThat and a new AFM hose should get you closer to running.
RKramden
Jan 27 2020, 10:42 AM
QUOTE(ClayPerrine @ Jan 27 2020, 09:46 AM)
It's on the list!
