QUOTE(bkrantz @ Jan 30 2020, 07:28 PM)
I see both of these for sale. Again, anyone know the difference?
Click to view attachment Driving Manual is broken down into the following sections:
Operating
Care & Lubrication
Maintenance & Adjustments: service intervals, compression testing, valve adjust, replacing plugs, points, timing adjust, bleeding brakes, clutch adjust, headlight adjust,
General Description: Engine, Transmission, Front Axle, Rear Axle, Steering, Brakes, Body, Ventilation System
Tech Data: VIN Plates, Paint Code, Chassis, Specs for Engine, Transmission, Electrical, Weight, Suspension, Fuel System Acceleration Curves, Transmission Diagram.....
I think a lot of the tech specs can be found on p914.org
