stevegm
Feb 1 2020, 11:53 AM
I have three rear glasses and I’m not sure which is for my ‘72?
Did ‘72 come with defroster in rear glass?
Beebo Kanelle
Feb 1 2020, 12:24 PM
Mine did
Mark Henry
Feb 1 2020, 12:36 PM
Some did, southern states destined cars usually didn't have them. Only a couple bucks of parts and labour, but lets say that X 50K of production was southern states, adds up. Typical of VW, they made a couple bucks extra on southern cars.
The wife's '72 and my '74 both have the rear defroster.
sixnotfour
Feb 1 2020, 12:55 PM
Check for wiring...
Cairo94507
Feb 1 2020, 12:58 PM
Do you have a rear window defrost knob on the dash?
914Sixer
Check for continuity of the sliver color lines. 95% are bad.Put volt ohm meter across the spades on the window, see if it 0's out. Most will have a high open.
dr914@autoatlanta.com
Feb 1 2020, 01:30 PM
as an option, yes
QUOTE(stevegm @ Feb 1 2020, 10:53 AM)
anderssj
Feb 1 2020, 01:32 PM
IIRC, you could order it on a new car as an option--I think for less than $100. I retrofitted my car (early 1972) years ago while stationed in Seattle area, but I don't think the wiring was there. I salvaged wires, switch, etc, from a wrecked car.
stevegm
Feb 1 2020, 01:59 PM
QUOTE(sixnotfour @ Feb 1 2020, 01:55 PM)
Check for wiring...
Good idea. I assume the defroster wire comes out of the center tunnel? Here is what I have. I’ll have to dig into it.
rgalla9146
Feb 1 2020, 02:10 PM
I think all early chassis had the wiring in the harness.
Every 6 I've worked on had it at the back of the tunnel.
