the problems ive been having w/ mine is, when you line the tdc up, then line the cap up w/ the rotor, there isnt enough adjustment either way to get the eye to line up correctly. I finally got it all set tonite, again, tdc, rotor pointing to #1, light on w/ led on leading edge....itll start, idle for two seconds then die. Over and over. WTF? Put in some different plugs, checked the injector pulses, everything is aok from what i can see. Itll start and idle perfect, if you give it any gas or move for that matter, it dies.
