I just edited my reply after taking a closer look at the schematic. IIRC, your are deleting your heat so don't need it?
BPic
Feb 2 2020, 10:54 AM
Correct. No heat. I just unwrapped the rest of the engine harness and the green to pin 11 and the white to pin 12 are cut and taped.
bbrock
Feb 2 2020, 11:00 AM
QUOTE(BPic @ Feb 2 2020, 09:54 AM)
Reading from the 73 schematic:
White to pin 12 connects to pin 13 on the 14-pin connector and both pins take power from the fuel pump relay?
BPic
Feb 2 2020, 11:05 AM
QUOTE(bbrock @ Feb 2 2020, 12:00 PM)
White to pin 12 connects to pin 13 on the 14-pin connector and supplies fuel pump. Was your pump relocated with power tapped from somewhere other than the black/red wire?
Well the harness is a hack job that I’m rebuilding with 2 harnesses. I put the pump up front and can tap into the original wires. May need to take a break from it. Looking at 2 harness both were hacked a bit. It’s getting a little confusing!!!
JeffBowlsby
Feb 2 2020, 11:53 AM
A 72 ignition harness does not jumper pins 10-11. The fan on a 70-72 car has individual wires from 10 & 11 routing directly to the fan in the ignition harness. The fan on a 73-76 car is fed from two wires branching out of the chassis harness. Don’t confuse the two, they are different.
bbrock
Feb 2 2020, 12:14 PM
QUOTE(JeffBowlsby @ Feb 2 2020, 10:53 AM)
Thanks Jeff! Yes, I was responding based on a 73 and POs car is a 72. Good catch!
