Just an FYI, I purchased an Odyssey PC925L for the 'BB' in 2012. It worked great, but then after attending the 2015 Rt-66 and the 2015 WCR, my clutch cable busted. I didn't get around to installing a hydraulic clutch release system until early 2018, so the car sat idle all that time - and the battery was never on the charger.
I thought I was going to have to purchase a new battery, as I put the car on the market the summer of 2018. I thought I'd try charging it and it took a full charge, turned my 9.5 C/R 2056 over just fine.
3 years with no charge, I was happily surprised ... a $130. battery. So much, that I purchased another one for my '71 914.
https://www.aircraftspruce.com/catalog/elpa...zQaAouQEALw_wcBThe PC925 measures 6-15/32" in length, 6-78" wide, and 4-7/8" tall. The battery weighs less than 24 pounds.
925 cranking amps for 5 seconds
870 cranking amps for 10 seconds
765 cranking amps for 20 seconds
Short circuit current over 2400A
28 amp hours
50 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
