Sold...New Sound System Upgrade......$100.00 for everything plus shipping
Some Specs on the amp which cost over $200.00 by itself.
4-channel car amplifier
50 watts RMS x 4 at 4 ohms (60 watts RMS x 4 at 2 ohms)
50 x 2 watts RMS + 120 x 1 watts RMS power bridged output at 4-ohms (4-ohm stable in bridged mode)
4- or 3-channel output (no 2-channel output)
CEA-2006 compliant
switchable high-pass filter on front two channels (80 Hz, -12 dB/octave)
switchable low-pass filter on rear two channels (80 Hz, -18dB/octave)
variable bass boost on rear two channels (0-10 dB at 40 Hz)
speaker-level inputs with high-level sensing turn-on
preamp-level inputs
MOSFET power supply
fuse rating: 40A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
8-1/8"W x 1-3/4"H x 8-13/16"D
Crutchfield gets $80.00 for the Petro Mod R-4562N speakers
Specs: 4" 2-way speakers (pair)
polypropylene woofer cone with Santoprene surround
Mylar dome tweeter
power range: 2-40 watts RMS (80 watts peak power)
frequency response: 65-21,000 Hz
sensitivity: 88 dB
top-mount depth: 1-5/16"
grilles included
