shane
Feb 9 2020, 04:22 PM
Preparing to bolt on the doors and was wondering did the hinge bolts going to the car have washers? Thanks in advance
914forme
Feb 9 2020, 04:34 PM
two actually per bolt
The PET is a great resource to have for these questions.
https://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf hyper link was not working right, most likely due to the PDF file.
shane
Feb 9 2020, 05:05 PM
QUOTE(914forme @ Feb 9 2020, 02:34 PM)
Great thanks for the heads up had no idea of PET file
nihil44
Feb 9 2020, 06:50 PM
Shane,
PET says door hinge is fastened by M8 bolt (length not specified but I think the bolt is 27mm long and pointed to facilitate installation), a lock ring (aka spring washer) and a flat washer (A 8,4 - which I deduce is 8mm OD and 4mm ID)
Good luck
David
nihil44
Feb 9 2020, 07:37 PM
Shane,
Another thought. To help installing doors, use one M8 stud in the top and bottom mountings in the door jamb to help you locate and steady the door while you put in the other bolts in.
You can make a M8 stud from a M8 bolt with the hex head cut off. This concept is not mine but borrowed from another thread using this technique to install the bumpers. Installing the doors can almost be a one man job using this technique.
Good luck again
David
Feb 9 2020, 09:12 PM
I use this company's version of the porsche pet. It's a lot easier for me to follow.
https://nemigaparts.com/cat_spares/pet/pors...14/570u/804000/
nihil44
Feb 10 2020, 01:51 AM
Mepstein,
Thanks for the heads up. I have come across their parts diagrams multiple times when Googling parts but didn’t know how to enter the site.
Their diagrams are much better definition than my PET PDF and easier to navigate.
Appreciate the info
David
Feb 10 2020, 06:48 AM
QUOTE(nihil44 @ Feb 10 2020, 02:51 AM)
Mepstein,
Appreciate the info
David
shane
Feb 10 2020, 01:36 PM
QUOTE(nihil44 @ Feb 9 2020, 05:37 PM)
Shane,
Good luck again
David
Yeah great idea!!! I always use that method when I’m putting a head back on so i don’t ding up the gasket. Thanks
nihil44
Feb 11 2020, 04:33 PM
Referring to my post #4 in this thread. My being dumb!
The PET description for the washer is A8,4. It has now dawned on me that the Germans write our decimal point (period . ) as a comma( , )
So 8,4 is our 8.4 which I guess is the ID of the washer, 8.4mm
There, I’ve fessed up
David
