Mikey914
Feb 10 2020, 01:57 AM
I have 5 of these NEW in box just like OEM.
These are not the threaded easy install version.
$88 each + shipping
stownsen914
Feb 10 2020, 07:51 AM
Which part isn't threaded?
76-914
Feb 10 2020, 09:13 AM
not threaded where the two tubes insert on the top!
Tdskip
Feb 10 2020, 11:01 AM
Oh boy - been through that on the 912. Air in garage still has blue tint several years later...maybe due to lack of skill on my part.
Mikey914
Feb 10 2020, 11:54 AM
NOT THESE is what I'm trying to emphasize.
Tdskip
Feb 10 2020, 02:25 PM
Got this from Doug;
Remove the reservoir clamp and pull the lines down as far as possible from underneath. This gives you a little more access to install the lines. With the grommets installed on the supply lines I use a small screw driver and go around each rubber grommet pushing it down into the hole of the MC. I usually have to go around each grommet several times and do it in stages. Too much force and you can poke through the rubber grommet. Install isn't too bad. Its not fun but once you know how to do it, it can go pretty quick.
a9146luvr
Feb 10 2020, 10:55 PM
PM'd
Mikey914
Feb 12 2020, 02:04 AM
4 left
