Full Version: What's This Tool ?
914Sixer
I thought I would see if the group had their thinking caps on. You only need this a couple of times. But the tool is very handy removing the part.
bbrock
Headlight switch removal?
914Sixer
You are close to correct. Escutcheon tool for removing all the dashboard nuts.
rhodyguy
I've had this for years. No idea what it is or what it's for. confused24.gif
914Sixer
It's for removing pins out of later VW and Audi pin plugs . Might be handy to push female ends out of relay board harness plugs.
bbrock
QUOTE(914Sixer @ Feb 14 2020, 01:36 PM) *
Your close to correct. Escutcheon tool for removing all the dashboard nuts.
Ha! I'm claiming it. I just said headlight switch because that's the only one with a shaft that prevents a good ol' nickel or penny being used for removal. biggrin.gif
76-914
I made one by cutting a slice from a washer but not nearly as nice as this one. Now is the time for someone to make those available in a non-scratch plastic material. One of these whiz kids could print some, I'm sure. beerchug.gif
