Greetings,
Finished installing the new turn and wiper switches and all seems well - other than the fact that the horn now only sounds when I hit the butterfly on the top center of the pad.
Nothing on either side of the butterfly or the bottom.
That seems strange.
All new insulating hardware has been installed as well as new rubber collar. Horn wire is tight connection.
New switch only has only copper leaf (as opposed to the two that the OEM one had) but I can't see that as an issue.
All wiper, signal, headlight and pump operation as normal....
