WTB: Adapter plate, flywheel, clutch, and pressure plate for LS swap. May be interested in the same parts for an SBC swap as well.
Thanks!
9144me2enjoy
Feb 15 2020, 10:22 PM
Looks like your fairly new to the forum, Welcome! You’ve probably done your homework on this conversion but if you haven’t you might want to check with Renegade Hybrid under 914 LS V8 kits. They have some pretty good options to get you started or complete your conversion. Depending on the Adapter plate you need for the transmission your going with, a beefed up 901 or 915 or 930 trans or a Porsche Boxster S 986 5 or 6 speed transmission along with stronger axles etc. or a Audi 6 speed trans..good luck with the build. You might want to start a thread under 914 World Garage for some knowledgeable forum members can help out which will save you a lot of time and probably a lot of $$!
Gearup
May 18 2020, 10:00 AM
QUOTE(AG914 @ Feb 15 2020, 04:31 PM)
Thanks!
I have a complete flipped 915 tranny SBC kit with everything to get your car running. Brett
