$1600 - This is a real 1975-1976 Porsche 914 2 liter engine. It has the 3 bolt cylinder heads and the angled spark plugs that only came on this engine. The heads have 1/2" tube vents built into them. All of the fuel injection stuff was taken off at some point in the past. I got this on a pallet from CA. The engine was pulled out and put on a pallet and stored in warehouse for a number of years. I got it, cleaned it up top to bottom. It hand turns fine. It still has the original distributor, points and condenser. I tested the distributor to be sure it worked. The following work has been done.
I have more pics if you want to see them, just ask!
cleaned top to bottom
original tested distributor
oil changed to Valvoline 20W50 high zinc oil "made especially for flat tappet push rod engines"
valve adjusted
new bosch spark plugs
new spark wires
new FRAM oil filter
new valve cover gaskets
valve covers and bails have been blasted and powdercoated satin black
914 flywheel included
fan hub included
As far as shipping, I am in Ohio, I do have pallets to set it on, your options are
1 - you come get it
2 - I can deliver it for a fee based on distance
3 - you can arrange truck shipping, i can send you a link, but i will not arrange the shipping, you got to do it.
