buck toenges
Feb 20 2020, 01:48 PM
I need part 9 on the pet katalog for fuel tank. It is part number 914 201 043 10. It is the larger of the two pipes under the fuel tank. If you have the union nut that goes with it that would be great. I currently have two of the smaller pipes that are used for the return line
Thanks,
Buck
914werke
Feb 20 2020, 03:29 PM
Chk my site. Pretty sure i have them. Id look but under car.
Chris914n6
Feb 20 2020, 05:20 PM
That's not un-normal. I forget if it's early or late but it can be 8mm & 8mm or 8mm & 10mm.
IIRC 75-76 is 8mm & 8mm because the pump is up front and it's 8mm & 10mm for the rear pump, the bigger being the feeder.
1 of the headaches of the 74 I'm doing is the tank is 10mm, the front mounted pump inlet is 12mm, and the outlet and SS lines and FI is 8mm.
