I have a 3 port Bosch FI pump D580463009 that came to me along with some other FI parts I purchased long ago. It had clearly been molested previously.
I decided to power it up. Yup, motor runs.
I decided to see if it would actually pump some alcohol since I didn't want to risk gasoline. Good thing . . . it leaks like a sieve.
Having nothing to lose, I decided to disassemble it. There was massive leakage out of the motor housing and the large O-ring that goes between the pump rotor base and the DC electric motor housing was clearly torn and rolled when I disassembed it and this is where the bulk of the leakage was coming from.
I'm wondering if someone can advise on what the criteria is for a core / rebuildable part since these clearly aren't cheap to rebuild nor are they easy to come by.
@914sixer
@dr914@autoatlanta.com
Here are some pictures for those curious about the intertnals of a 3 port rotor pump.
Rotor inlet & outlet housing:
Pump rotor and vanes:
The motor rotor, windings, and brushes:
And finally the inside of the motor housing / stator permanent magnets
