QUOTE (brant @ Jul 5 2005, 01:36 PM) |
some people claim to get 225's under the rear... I'm not one of them but the front is fine. they will rub the inside fender well at full lock, but the solution is to not turn that sharp. I've run 7inch cookies and 225's on 2 different cars and had NO problem with front fitment. brant |
QUOTE (brant @ Jul 5 2005, 01:54 PM) |
I think its the back side of the tire that rubs... don't know how much spacer exactly.. There isn't a ton of room on the outboard side (depending upon how low the car is) so I never tried spacers.... plus, you would need to buy 10 longer studs too. sorry can't answer your question. Maybe someone else knows. brant |
QUOTE (bondo @ Jul 5 2005, 01:58 PM) | ||
Does anyone know if 215s don't rub? If that's the case, a 5 mm spacer SHOULD do it. |
QUOTE (brant @ Jul 5 2005, 02:59 PM) |
I think that compared to a 6inch cookie... the 7inch is exactly one inch wider in track. so that would be a good goal... maybe a tiny bit more for safetys sake. brant |
