QUOTE(larss @ Mar 5 2020, 06:12 PM)
I have some good working yellow and black (pre -71) Bosch injectors which all came out of 1.7 stock engines.
I flow tested them at 43.5psi (3.0bar) and they all had a flow around 370cc/min.
Also tested them at 32psi (2.2bar) and they all had a flow of around 320cc/min.
This looks way too high to me since they all hav a rated flow rate 265cc/min at 43.5psi.
Anyone have any input on this?
/Lars S
Hi Lars,
Bosch produced 'early black' D-Jetronic-injectors in 3 different flow rates. You have to check the Bosch # to be sure they fit. Tell me the # - I can check it.
Your question concerning the flow rate: Bosch used a special testing fluid, no fuel for testing. More like naphta, a standardizised fluid. The flow rate of the D-Jet-injectors was tested at 2,0 Bar or 29 psi.
Other injectors - like that for the L-Jetronic- were tested at different pressure.
Some comparisation tables note all ijectors tested at 3,0 Bar to make them comparable. But there are some obvious mistakes in the tables I know, maybe they copy from the others...
Injector rebuilders normally don't measure the flow rates but compare the injectors to the others of the same type only.
Regards
Norbert
