Don't want to hi-jack this thread, but had a weird thing happen to my 0 231 181 009 dizzy re: centrifugal advance. Last Thursday, engine was running perfectly with Pertronix 1847V ignitor that seemed to fail.
I put points in the dizzy, and now the centrifugal advance does not work at all. Did nothing but pull the dizzy, put in points, all centrifugal advance gone. Yesterday put in Hot-Spark ignitor which of course changed nothing.
Will rebuild the dizzy next week and see internally what stopped the weights from working.....but no idea what would bring the change....no, did not drop the dizzy.
Meanwhile, put a new Hot-Spark ignitor in my old 0 231 178 009 and its CA is working fine. Just prefer the advance curve in the 181...
Oh - and as I'm running Webers, I'm not using, nor do I need, the vacuum advance/retard......
GN
QUOTE(Robson51 @ Mar 5 2020, 05:30 PM)
QUOTE(GregAmy @ Mar 5 2020, 11:30 AM)
Just curious: why do you want to remove it? Are the pots damaged?
PO only had advance hooked up. The more I looked into it, it almost seemed like it's basically a centrifugal distributor with vacuum only to help it through some rough patches.
I just thought I would ask.
