914LIVE
Mar 7 2020, 07:18 PM
For Sale :
Four (4) MPS modules from running
Porsche 914s.
1) 0 280 100 037
2) 0 280 100 043
3) 0 280 100 027
4) 0 280 100 049
$ 225 each plus actual/true shipping.
Thank you.
Click to view attachmentClick to view attachment
Superhawk996
Mar 8 2020, 10:42 AM
Pics of end caps requested. Has the adjustment screws been opened?
kkid
Mar 8 2020, 10:45 AM
Do you have access to a vacuum gauge to see if the units hold vacuum adequately?
914LIVE
Mar 8 2020, 01:10 PM
Will do the VACUMM TEST again
and report back.
One module is unmolested on the
screw access.
Three of the modules have the
screw access point opened.
Superhawk996
Mar 8 2020, 02:52 PM
QUOTE(914LIVE @ Mar 8 2020, 02:10 PM)
and report back.
screw access.
Interested in the 037 -- is that one of the molested ones?
914LIVE
Mar 8 2020, 06:58 PM
Unmolested is the 027.
914LIVE
Mar 9 2020, 07:02 PM
MPS Update :
Vacuum at 10 inHg vac.
1) # 027 holds at 15 minute test (no losses)
2) # 049 holds at 15 minute test (no losses)
Other two units pending testing
Thank you.
JeffBowlsby
Mar 10 2020, 03:18 PM
The 027 is not a 914 MPS, I think it may be for a 411/412
The pressure test is for 15 in/HG, and industry literature uses 18 inHG. If fit leaks, it should leak fairly quickly. 10 inHG is not sufficient.
914LIVE
Mar 10 2020, 11:58 PM
No problem.
I will increase to 18.
Update soon.
914LIVE
Mar 10 2020, 11:59 PM
027 used in two 1973 914s.
914LIVE
Mar 11 2020, 02:37 PM
Increased test to 18 inHg vac on both
the 027 and the 049 and absolutely
NO LOSSES.
30 minutes on both and NO LOSSES.
Thank you.
