QUOTE(IronHillRestorations @ Mar 9 2020, 07:08 PM)
If you changed out the steering column cover and switches to the later style, couldn't an early car accept a later harness?
Partially correct. Review each characteristic of the later harness being considered and see if you need to make any changes.
A few examples in addition to the steering columm switches:Ignition switch type/connection
Want the seat belt relay under the pass seat or the fasten seatbelt dash light?
Early/late door switches were different
Early/late headlight motors were different
Dash gauge selection/wiring varies with the model year
yada, yada...
