Inching closer every night.
I would sincerely like to have this thing moderately operable enough to drive 1 mile by the weekend of the 11th. I have too much pride, after spending this much effort on this thing, to tow it 1 mile to my new home.
Today's only major issue - there is, of course, at least one every other day:
I tried to shift the car for the first time while on, horrible GRIND and then nothing. Goes into (I believe) every gear while off.
I know the tail shift is bad... but it at least goes into gear right?
Here's what I attempted to remedy/diagnose this:
1. I put it into 1st then turned the car on, it lurches (same with reverse)
2. I read the Haynes trouble shooting.
3. I read the John Muir shifting issues, but nothing stood out, might not apply as much, being a 914.
4. I adjusted the clutch cable tighter, three different lengths. It makes a huge difference in the pedal feel, but no different on the grind.
-The clutch and pressure plate were never separated, have tons of meat. -flywheel matched those too. (all same car)
-Shifter bushings are all brand new.
Wondering if this is a throw out bearing issue. I sure hope not.
Any thoughts?
Part 2:
I finalized some fuel pump wiring, buttoned up the interior, set the car down, and installed a triple gauge panel. Oil Pressure, Temp and Volt.
I used the 42Draft Designs Universal panel, and used it as a radio delete.
Here is a photo:
I am really happy with how the interior has turned out.
I do need to get a new voltage gauge that sits in flush, that would look correct.
Oil Temp Gauge doesn't function all the way, but gets power, gotta figure that out.
I ran the motor for a while and adjusted the carbs a bit more.
Looks like a complete car.
New trunk (that actually closes) courtesy of Mepstein. He'll be getting a Christmas card this year.
That's all for this evening.
