Teeners!
I redid all of the pushrod tubes and the valve covers (did the oil cooler gaskets earlier - with the Engine In!!!).
Of the pushrod tubes all seem tight with the exception of Cyl 1 Exhaust!. UGH
The others seem pretty tight - ran the car for 15 min at 30-40 mph prior to inspecting.
Some of the others:
Question is what do you do if there is a leaky tube? I will replace the tube (i have a few new ones) with new vitron gaskets, however, should I get out the RTV?????
Thanks!
Should start a thread called: What dis you do TWICE today to your 914?
