Since the Virus does not like heat or UV-3, I figured what would make me the safest guy on the planet.
Some welding, so out came the TIG and MIG, and we started to weld, and weld, and weld some more.
First thing I did was weld up a gantry crane, we had one at the farm shop for years I forgot how handy they are for everyday tasks. IT is still not ready for prime time pictures but I pressed it into service today, lifting some gas cylinders, righting a tool box I had on its side wot weld up a ZTFab welding cart.
Click to view attachmentOf course I could not leave well enough alone, and decided to change the mounts for the axles so they have a bit more meat to hold them true. And then I don't like safe chains as my main way of keeping a bootle on the cart, so I took some bottle wall mounts, and fabricated a mount so they work on the cart. I got them from my welding supplier they were 17, and 22 respectfully, less than the cost for me to fabricate them. Bottles going no where.
Click to view attachmentEverything loaded up on the US General tool cabinet. I used to have all of this on two craftsmen boxes. They will be repurposed for a bench I am building.
Click to view attachmentNext I picked up a quick jack right before our governor tossed us into lock down. Paid $500 for the 7000 lbs version. Issue is it is not easy to move. So I saw an idea on the internet, and I decided it was to complicated. I had these from an outfield stand, and well they never out feed correctly, and two I am using them to support long picks of tube and steel so I can fixture on the welding bench. So I had a bunch of them.
Click to view attachmentMounted them to the lift arms, so that when it comes down the weight of the lift is a fulcrum and the wheels will lift the bottom of the lift up about 1/4"
Click to view attachmentNow it is easy to move around the shop.
Click to view attachmentThats all for today, hopefully get back out tomorrow go through stuff and cleanup a bit. Need to get lawn equipment in for service, and winter tires off the 7 series.
Means I can
like I like to.
