QUOTE(914Sixer @ Mar 26 2020, 03:51 PM)
If you run SC rear hubs you need the 5mm spacer they sell to put on the hub before you press in the hub. Recommend you run the 100mm SC stub axle. You can use 944 or VW Bus CV
This is the setup I'm going to run in my 914-6 when it's done.
I have the later 74-89 centric front and rear hubs w/PMS spacers ( my parts are from a 84 911 Carrera). Using modified 914 axles and new 944 100 mm 6 bolt cv joints, mid year 911 6 bolt trans output flanges and SC hub spindles. True 5 lug bolt in solution.
There's some good info in the classic section as well.
