This is one of those things that bothered me; just not very much. Took a plague to motivate me to do this. So the BMW mirror is an improvement especially if you like to see out the entire rear glass. I like mine but the pin that fit in the drivers side visor would come loose when I moved the visor and usually at a bad time. The psg side was fine and never come loose so maybe no one else has had this problem? I drilled out the other plastic pin and opened the hole enough to true it. Then I turned down a piece of aluminum, centered it, drilled/countersunk for rivet, set rivet. The visors won't fall off again.
