bdstone914
Apr 1 2020, 11:34 AM
Edit, Have ten more sets available.
I have seen many cars that deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in.
I made these to cover the holes and look better than a paint cap stuffed in the hole.
I can supply them bare if you want to paint to a special tin color.
Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts.
Price is $27.50 per set shipped.
PMs will be sent to those who replied to this thread.
BPic
Apr 1 2020, 11:36 AM
YES PLEASE! 1 - Set
Jim C
Apr 1 2020, 12:20 PM
QUOTE(bdstone914 @ Apr 1 2020, 12:34 PM)
I have seen many cars tha deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in.
I think I could makes these fairly inexpensively. Price would be $20-$25 a pair.
They would be powder coated black and attach thru the hole in the tin that is for the J tube attachment screw.
I'd be interested.
Gint
Apr 1 2020, 12:25 PM
At that price, I'd take a set to put on the shelf. I'm in for one.
abes914
Apr 1 2020, 12:32 PM
i am in for one as well.
Literati914
Apr 1 2020, 12:49 PM
Yes I'd like a set as well.
DMAYHALL
Apr 1 2020, 03:10 PM
I'm in for a set !!!
Alapone
Apr 1 2020, 03:30 PM
id take a set
JeffBowlsby
Apr 1 2020, 04:13 PM
I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic.
bdstone914
Apr 1 2020, 08:49 PM
@JeffBowlsby I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic.
[/quote
Good idea but I do not find that type of metal cap plug available in sizes over 2". Larger plastic plugs are available but the only ones I found were bright green. Also the clearance to the vertical wall on the cylinder tin is only 3mm so the head may hit.
One issue I see is that most tins are bent up and the plate may not sit flat.
Optimusglen
Apr 2 2020, 07:43 AM
I'm definitely in for a set.
Jim C
Apr 2 2020, 07:58 AM
I found some 3" flat black plastic plugs on Amazon which, along with some black RTV, covers the holes. For how long I don't know. I am certainly open to a more permanent solution.
Craigers17
Apr 2 2020, 09:56 AM
I'm in for a set.
bdstone914
Apr 25 2020, 08:07 AM
Bump. Should have finished parts in about one week.
bdstone914
Apr 29 2020, 01:28 PM
Bump, available now.
Jim C
Apr 30 2020, 09:39 AM
@BPic @jim C
@Gint @abes914 @Literati914 @DMAYHALL @Alapone @Optimusglen @Craigers17 I'll take a black pair
Edit #3.
Plates are made and getting powder coated satin black today. I can supply them bare if you want to paint to a special tin color. Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts.
JamesM
Apr 30 2020, 09:56 AM
Ive thought about doing something, always hated that open hole. Ill take 3 sets.
Literati914
Apr 30 2020, 10:08 AM
payment sent. Thanks Bruce!
abes914
Apr 30 2020, 11:45 AM
Payment sent. Thank you!
Craigers17
Apr 30 2020, 03:34 PM
I might have missed it somewhere, but what is your preferred payment method? I'll get you the funds ASAP. Very Nice work....thanks!
-Craig
Gint
May 5 2020, 06:16 PM
PM coming. Thanks Bruce.
bdstone914
May 5 2020, 07:08 PM
QUOTE(Gint @ May 5 2020, 05:16 PM)
Got two pairs for you.
Rikyrat
May 14 2020, 10:25 PM
Is it too late to get a set.
bdstone914
May 15 2020, 07:23 AM
@Rikyrat ' date='May 14 2020, 09:25 PM' post='2815345']
[/quote]
I still have many sets.
I will PM my Paypal address
bdstone914
May 24 2020, 08:37 AM
Bump, many more sets available
mdelwiche
May 24 2020, 09:20 AM
I’ll take a set!
porsche914gt
May 24 2020, 10:28 AM
I'm in for a set. Thanks.
chilling in vt
May 28 2020, 04:21 PM
Not quite sure how the 914 heater hose sizing compares to a 911, but will these fit an early 911? Or do you make something like this for them?
bdstone914
May 29 2020, 09:05 AM
@chilling in vt
' date='May 28 2020, 03:21 PM' post='2819945']
[/quote]
I think the 911 hole size is the same as the 914. Depending on what tin you have there may be a lip around the hole that may interfere.
I have unpainted blanks. I can probably form a set to work but would need to know the sixe of the lip.
Can you post a picture of that area of the 911 tin.
minime904
Jun 1 2020, 08:12 PM
QUOTE(bdstone914 @ May 5 2020, 07:08 PM)
I'll take a set if not too late. Thanks
bdstone914
Jun 1 2020, 08:37 PM
QUOTE(minime904 @ Jun 1 2020, 07:12 PM)
Not too late. PM sent.
sjhenry1075
Jun 3 2020, 06:58 AM
I'm in for a set as well.
bdstone914
Jun 3 2020, 08:09 AM
@sjhenry1075 ' date='Jun 3 2020, 05:58 AM' post='2821640']
[/quote]
PM sent
9won4
Jun 6 2020, 02:40 PM
I'm in for a set. Thanks!
bdstone914
Jul 1 2020, 11:15 AM
bump, still have several sets available
bdstone914
Aug 12 2020, 12:26 PM
Bump, more sets painted
Tdskip
Aug 12 2020, 12:38 PM
Can I get two sets please Bruce?
bdstone914
Aug 12 2020, 12:55 PM
QUOTE(Tdskip @ Aug 12 2020, 11:38 AM)
Yes since you said please.
porbmw
Aug 12 2020, 01:29 PM
Ein set bitte
Paul
kkid
Aug 12 2020, 06:06 PM
I have missed this post from April.
Please PM me if you still have a set.
Thanks in advance,
kkid
simonjb
Aug 14 2020, 05:42 PM
I would like a set please !
bdstone914
Aug 29 2020, 10:49 AM
Bump, still have sets available
G e o r g e
Aug 30 2020, 12:14 AM
Bruce,
Set 2 sets away for me.
