QUOTE(ThinAir @ Apr 19 2020, 12:03 AM)
That light has been on my car for about 10 years. I've never opened it up so I don't know about the internal construction. Is there glass between the outer "lens" and the bulb? If so then I would think it is just stuck in place from age since it would need to be removed to change the bulb. I'm thinking that a razor to cut through the seal would be what I would try. I would think it could be resealed.
There are 4 parts to the Pilot fog light:
1) The rear support enclosure.
2) The ring holding the glass lens and metal reflector to the support enclosure.
3) The glass lens
4) the metal reflector and bulb holder/socket.
The glass lens and metal reflector are sealed with something that i can't get apart. The metal reflector has a lip that keeps the glass lens in place thus a razor knife cannot be inserted to cut whatever is holding the lens and reflector together.
I don't feel comfortable using a screwdriver or other utensil to try to pry the 2 apart. I'd rather you try to take apart the one you have they tell me how to separate the 2. I don't want to break your fog light.
I've encountered a foglight from a 911 where the glass lens and reflector seemed to be bonded together. I had to bail on trying to separate them.
