Bulldog9
Apr 7 2020, 03:33 PM
Using the downtime to clear out some of my leftover parts. All parts unless noted are new and never installed or run. Prices are + shipping. All prices are less than 50% off MSRP, but willing to deal, bundle and move these parts.
UPDATED TO REFLECT SOLD PARTS PM for pictures and details, or more information.
911/912E URO Rear glass weather strip - $25.00
911/912E Porsche Rear Engine Compartment Seal - $25.00
912E Exhaust Gaskets (OEM Porsche #923 11 151 01+C201) - $20.00
911/912E Transmission Mounts (2) - $25.00 *test fit installed, never run. I went with sport mounts instead
911 Front door harness and door wiring dust caps - $10.00
*Used, taken from door of an 86 Carrera
914 Alternator Cooling Plate (2) - $10.00
*Used, good condition
3 POD Plastic 2" VDO Gage Holder - $5.00
2" 12V VDO Clock - $35.00
*test fit installed, ended up using original
911 Heat and volume (control) missing fan switch - $5.00
Used from salvage
911 Headliner Tension Wires 1-4 - $30.00
914 Reman Alternator New never installed - $75.00 SOLD
CB Performance Cross Bar Throttle Linkage Pack - Includes Steel Hex Cross Bar - 20 5/8" - $50.00 SOLD
911/912E Front glass weather strip (OEM Made in Germany) - $50.00 SOLD
912E/914 CB Performance Air Filters/Bases with hardware - $25.00
*test fit installed, never run. I went with a pulley system instead. SOLD
SCAT bell crank Throttle control linkage - $40.00
912E/914 Original Customs Throttle Cable Bracket - $10.00 SOLD
912 E Bursch Exhaust (C 1990) New never installed - $225.00 SOLD
914 Sachs Throwout bearing and bushing caps - $50.00 SOLD
NOS Bosch distributor cap and rotor kit (extra cap/condenser) -$10.00 **Fits stock distributor. Truly NOS, is in plastic display package. Will also throw in an extra cap and condenser. I am running the Pertronix plug and play (large distributor) SOLD
Set of Lemforder Tie Rod Ends 10710 03 009 - $25.00 **NEW IN BOX. This is for the stock rack and tie rods. I went with the turbo rack which uses different tie rods. SOLD
912E/914 Bosch Fuel Pressure Regulator (Porsche box) - $70.00 SOLD
911/912E Clutch Pedal Return Spring - $5.00 SOLD
stevegm
Apr 7 2020, 03:53 PM
I will take all of the parts that fit a ‘67 912. I will look at the list closer. I just need to figure out which ones will fit.
Literati914
Apr 7 2020, 04:04 PM
I'll take the throttle bracket, tie rod ends, &...
Literati914
Apr 7 2020, 04:06 PM
..oh yea, gauge pod too.
Jack Standz
Apr 7 2020, 05:47 PM
Hi, I'm interested in the following two items, but want the alternator if it is a Bosch and the T/o bearing if new. Photos would be nice if you send. Thanks.
Literati914
Apr 8 2020, 07:29 PM
Pm sent.
Bulldog9
Apr 9 2020, 07:26 AM
QUOTE(Jack Standz @ Apr 7 2020, 03:47 PM)
Sent a PM, but yes the T/O bearing is new, never installed. The Alternator is from E-Bay seller BNR parts, and was the high output version. I can't see a difference, but will go out to the garage and see if it says Bosch anywhere on it.
bdstone914
Apr 9 2020, 08:48 AM
@stevegm ' date='Apr 7 2020, 02:53 PM' post='2801877']
[/quote]
Not many. Big difference between a SWB 912 and a 912E
ndfrigi
Apr 9 2020, 09:26 AM
pm sent for 3 items
stevegm
Apr 9 2020, 04:22 PM
[quote name='bdstone914' date='Apr 9 2020, 10:48 AM' post='2802424']
[/quote]
[/quote]
I know. Really, I don’t think there are any parts that will fit my car. Maybe the Transmission Mounts?
Bulldog9
Apr 10 2020, 06:52 AM
Updated list to reflect parts sold.
stevegm
Apr 10 2020, 08:34 AM
Does anybody know if the tranny mounts will work on a '67 912?
Apr 10 2020, 08:57 AM
QUOTE(stevegm @ Apr 10 2020, 10:34 AM)
Steve - This PET site is one of the best for showing parts for Porsche cars.
https://nemigaparts.com/cat_spares/pet/porsche/911-1/573u/ @stevegm
stevegm
Apr 10 2020, 09:15 AM
QUOTE(mepstein @ Apr 10 2020, 10:57 AM)
https://nemigaparts.com/cat_spares/pet/porsche/911-1/573u/ @stevegmThanks. I was just working on that. I don't think anything here will fit.
Bulldog9
Apr 11 2020, 08:54 AM
**ALL PARTS that I have received payment for have been shipped. USPS priority boxes. Delivery is supposed to be Monday or Tuesday April 13 or 14.
malcolm2
Jul 7 2020, 08:27 PM
ALT cooling plate????
Is that the plastic cover that kinda seals up the opening on the pulley side?
I also need the curved ALT bracket. You got that?
Clark
Mikey914
Jul 9 2020, 07:27 PM
I'll take the headliner tension wires. zip is 97124
Just let me know where to pay
