Tdskip
Apr 9 2020, 09:33 AM
Good morning gentlemen, hope everyone is getting on OK.
I know that it is a fairly common issue to have oil temperature gauge / sensor mismatch issues. I’m asking because the red (former turbo) car has a non-orginal to the car VDO gauge and what I believe to be original style sender on the rebuilt 2.0L.
My question is if there is a practical way to measure and calibrate the gauge to use as-is or is the only real solution to buy a matched set and be done with it?
Thanks in advance for the education.
914Sixer
Apr 9 2020, 09:55 AM
Vdo sending units are marked the range that they work to in C. Roughly 150C=300F. Mater of matching gauge range to sending unit. For gauges with no numbers (in some cases), you can look at an angle and see the number marks.
Tdskip
Apr 9 2020, 10:22 AM
Thank you.
The indicator temperature is warmer than it should be, I suspect the gauge is probably off because everything else seems OK.
Hope everyone is doing well in TX.
ClayPerrine
Apr 9 2020, 01:03 PM
There should be a part number on the gauge. IF you have that part number, a good parts guy should be able to find the proper sender for it.
@partsguy22 Has always been able to do this for me.
Clay
GregAmy
Apr 9 2020, 01:08 PM
