QUOTE(Dr Evil @ Apr 12 2020, 07:40 PM)
Howdy folks!
As mentioned, shifting on the bench is crap. It really can’t tell you much of anything. The only thing you are really doing when you are shifting from 1,2,3,4,5 is changing the ratios as the gears are always intermeshed. In 4/5 the output just turns faster.
When you flipped the differential, did you swap the bearings and spacers from side to side, at least? Did you check backlash? Too much back lash will be more prevalent in sound as you spin the ring and pinion faster (in 4/5 on the bench). If you simply flipped the diff and installed, start with swapping the bearings and spacers and see if that helps.
I hate to be the barer if further bad news, but if you did not use the jig to reassemble the stack and set the shift rods, it’s gonna shift like crap and have other problems as well as a shortened life (maybe you get lucky?).
Hello, thanks for your answer.
I replaced the diff bearings and moved the spacers from the one side to the other, I checked the backlash and it was 0.15mm
I removed the stacks along with their forks from the intermediate plate because I don't have a jig to set them up properly . I only needed to replace the input shaft bearing and the first gear dog teeth and syncro.
The sound I hear is mostly from the input shaft. Is there a chance that oil hasn't reached its bearings with bench testing or that the new bearing needs some break in ?
When I spin the gearbox from its output flanges I get no noise at all .
Also its turning smooth, no obstructions or changes in resistance It just makes a ticking noise when turning in 4th and 5th without any load. If I touch its flanges when rotating it is better I believe .
