Ampex351
Apr 8 2020, 10:11 PM
The '73 we just bought is a 4 speed. Any opinions? Good or bad?
Thanks!
Krieger
Apr 8 2020, 10:18 PM
The 914 only came with a five speed. Your linkage may be out of adjustment or some of the bushings may be worn or broken.
Ampex351
Apr 8 2020, 10:51 PM
How many of you prefer 5 over 4 speeds? The car we bought is a 4 speed. Good, bad, ugly? I know that 5 speed was an option in the day correct?
bretth
Apr 8 2020, 11:02 PM
QUOTE(Ampex351 @ Apr 8 2020, 11:51 PM)
If you are talking of 914s then you are missing a gear. They only came in 5 speed.
falcor75
Apr 8 2020, 11:35 PM
Its a dogleg gearbox, first is below reverse, chances are that you have mistaken second for first.....
Bmw635
Apr 8 2020, 11:50 PM
Or miss counted reverse as it requires push down lockout before shift into gears.
porschetub
Apr 9 2020, 12:37 AM
Never an option 5 speed only on a 4cyl car,cheers.
Mark Henry
Apr 9 2020, 03:23 AM
914 were all 5 speeds, 60's 912 and 930 were 4 speeds. IIRC
Some V8 builders would leave 1st gear out, as it's a weak gear for drag race starts. Most big engines can easily start off from 2nd.
When I first got a 914 I thought it was a 4 speed and wondered why it was such a dog in 1st (which was really 2nd) till I read the owners manual.
billh1963
Apr 9 2020, 06:42 AM
VaccaRabite
Apr 9 2020, 07:26 AM
QUOTE(Ampex351 @ Apr 9 2020, 12:51 AM)
By any chance is your car a v8 conversion? Many of those have been converted to 4 speed boxes. Stock they were all 5 speed.
Zach
Cairo94507
Apr 9 2020, 07:35 AM
Uh oh....... I hope the seller just assumed this car was a 4 speed and it was not something the seller told him. That would raise my suspicions about anything else they may have told him. I am hoping he actually laid hands and eyes on this car before making the purchase or at the minimum had a PPI by a knowledgeable 914 owner, etc.
914e
Apr 9 2020, 09:05 AM
Sadly I need the pattern displayed on all my cars. The pattern is different in each one. Otherwise I'm in driveway hunting for reverse.
I think the PO of mine 914 just left it in second or third all the time There was switch to reverse. He didn't even think it still had a clutch. I was happy to find it still did.
lierofox
Apr 9 2020, 12:11 PM
Yeah if the transmission is stock, 99.99% guaranteed it'll be a dog-leg 5 speed manual. Also...
Ampex351
Apr 9 2020, 03:25 PM
The green 2.0 we just bought is a 4 speed. Besides gear pattern and lower rpm's at higher speed is there any benefit to a 4 speed vs 5 speed? Just looking for opinions.
Thanks!
Apr 9 2020, 03:36 PM
QUOTE(Ampex351 @ Apr 9 2020, 05:25 PM)
Thanks!
It's only 4 speed if someone left out first gear. No 914 was built that way from the factory.
Chris914n6
Apr 9 2020, 03:53 PM
As stated in your other thread, there was no 4 speed transmissions in 914s.
Your car either has a mis-aligned shift rod, worn shift rod bushings, or internal component failure.
Craigers17
Apr 9 2020, 04:10 PM
....maybe one of the previous owners swapped it with an older 911 or 912 4 speed tranny and put a 914 tailpiece on it..... I read about someone doing this in another thread here. That would account for the 4 speed.... I think the owner was told this was an original car, but the mirrors aren't....maybe the transmission isn't either?
mrholland2
Apr 9 2020, 04:11 PM
Weren't the Sportomatics 4 speed?
QUOTE(Chris914n6 @ Apr 9 2020, 02:53 PM)
Ampex351
Apr 9 2020, 05:04 PM
QUOTE(mrholland2 @ Apr 9 2020, 05:11 PM)
Thanks guys...I thought they were all 5 speeds but the damned salesman told me on the phone it was a 4 speed. I thought he was full of it. I appreciate your input. I'm told that all gears work fine except 5th (by another salesman) And it grinds going into 5th.
billh1963
Apr 10 2020, 04:33 AM
QUOTE(Ampex351 @ Apr 9 2020, 07:04 PM)
Have you actually laid eyes on the car?
I'm afraid you are going to experience some disappointment if you are relying on a salesperson's description of the condition of the car.
911GT2
Apr 10 2020, 04:44 AM
QUOTE(billh1963 @ Apr 10 2020, 02:33 AM)
Yep that's a lesson I've learned the hard way
Please make your checks carefully!
Gatornapper
Apr 10 2020, 06:57 AM
That little Type IV engine would really be a dog with a 4-speed.......the engine demands a 5-speed for half-way decent performance, but my 2.0 does fine with it - IMHO....
No, no manual tranny's made in 4-speed, as all have said......
GN
QUOTE(Ampex351 @ Apr 9 2020, 03:25 PM)
Thanks!
brant
Apr 10 2020, 07:57 AM
QUOTE(Craigers17 @ Apr 9 2020, 04:10 PM)
A bug or 911 4 speed would have to have the ring gear flipped.
Or else 4 reverse gears
I seriously doubt someone put a grand of labor into flipping the ring gear on a 4 speed box
