Three restored engine fans. One late with the flat center, two early with the cone shape in the center. They will fit all years and engines. The fans have been marked at 0 degrees and 27 degrees. The adjacent fin is also colored to help with timing.
The early fans need shorter installation bolt to prevent contact with the crank seal.
Fans and rings were marked and installed in original orientation to keep factory balance.
Rings are powder coated.
$100 each shipped.
