When starting up, ALT light is on and VM shows discharge (about one needle width). After a while, revving the engine extinguishes it and that is mimicked by the VM. After a bit longer, it charges normally. If I let it sit for a day, repeats the behavior.
Checked the belt and it has 1/2” or less slack. Grounding out the VR gives me 16+/- volts at the battery cable. I installed a spare VR that I had (condition unknown) and got pretty much the same behavior. Cleaned the grounds, no change.
Suggestions?
