Just checking to see if anyone else has run into this problem. Everything was working great. I had low, medium and hit speed. Was working on the car again and now the fan is always running with the key on, on low speed, Still goes in medium and high. Pulled the wires from the control inside the car and it still runs. If I pull the relay it stops. I switched the relay with a different one thinking maybe it bad but still is running.
thank you
