QUOTE(frostyf @ Apr 13 2020, 08:11 PM)
QUOTE(cary @ Apr 14 2020, 01:16 AM)
QUOTE(southernmost914 @ Apr 13 2020, 04:29 PM)
PVC next to the oil fill.
That would be my guess too. We should be seeing a vertical hose next to the oil filler.
It has a clamp. That is one of the loosest hose fitting .
Hi, I might have mis led you. It is the grey braid covered hose I'm trying to fix. Having done some more studying I think it's coming out of the vertical spigot on the flashback valve and should probably go to the air filter box. Does that seem correct??
Click to view attachmentI've marked it with a red arrow on this photo from a different angle. I'm not sure it should be braid covered. Mine is brittle and needs replacing and the spigot on the air filter box which I think it goes seems huge. Does anyone have any suggestions on where best to source replacement hoses??
Based on Jeff's diagram and the way mine is routed, the yellow "X" in the attached photo is where that hose goes. There may be kits out there that contain "pre-cut" lengths of hose for each piece, however MOST of those vacuum hoses are all the same diameter, save one or two. That said, I know 914 Rubber has that hose because I just bought 12 Ft of it from them a few weeks ago. Basically, I'm refreshing my system the same as you. You might have to email Mark because I don't think it's on their site, but they do have it. Hope this helps.
