So I dropped the fuse panel to tap into a ignition power on and cranking only voltage yesterday for my Honda ECU.
I happened to notice some fried wiring for the fog light switch (car had what I believe to be halogen Pilot driving lights)
See 1st pic.
Issues on the fuse panel a wire (green square) that was cut and soldered, electrical tape falling off.
Burnt red wire (pink square) and some sort of double relay going to I think a headlight relay (orange rectangle)
I removed the relay contraption and opened it up, it had 2 small 10amp pcb board mount type relays.
Back to the smoke. When I was testing the lights and turned the ignition switch I saw light puffs of smoke from what looks like the ignition switch and steering column.
Ideas of screw up?
