Like it says, I'm looking for Targa Latches and Front under cover. Not sure if there are early and late but if so I need late. Car is a '75. Very good to excellent condition. Thanks. Joe.
johnhora
Apr 14 2020, 03:24 PM
Joe...I think I have an extra steering rack cover....will check the parts stash
porschetub
Apr 14 2020, 03:38 PM
bdstone for the latches if he has any stock,bought rear ones he had reconditioned,very nicely done.
bdstone914
Apr 14 2020, 04:22 PM
@JOEPROPER ' date='Apr 14 2020, 11:20 AM' post='2804282'] Like it says, I'm looking for Targa Latches and Front under cover. Not sure if there are early and late but if so I need late. Car is a '75. Very good to excellent condition. Thanks. Joe. [/quote]
Here is a set of late targa latches with remanufactured hooks. I have several steering rack pans too.
JOEPROPER
Apr 15 2020, 07:09 AM
Thanks for the responses. I should've been more specific. I need front targa latches. The handle part is missing from mine. Also looking for one of those small hole plugs that goes in the front targa pad above the visors. (In the picture)Click to view attachment
bdstone914
Apr 15 2020, 07:42 AM
@JOEPROPER ' date='Apr 15 2020, 06:09 AM' post='2804568'] Thanks for the responses. I should've been more specific. I need front targa latches. The handle part is missing from mine. Also looking for one of those small hole plugs that goes in the front targa pad above the visors. (In the picture)Click to view attachment [/quote]
I think all front targa latches are the same. I have a box of them. Just used notvtmrefinished.
JOEPROPER
Apr 15 2020, 07:53 AM
@bdstone914 Are mine broken or just missing the handle? Do you have the little plug?
date='Apr 15 2020, 06:53 AM' post='2804582'] @bdstone914 Are mine broken or just missing the handle? Do you have the little plug? [/quote] Probably just missing the plastic handle. That is what breaks most often. Yes I have screw cover plugs
johnhora
Apr 15 2020, 02:41 PM
Joe... Here's the steering rack cover I have... it's a decent solid one with no rust thru problems good mounting holes just needs surface rust to be cleaned up and painted let me know if this would work. Thanks...John
