QUOTE(Jrbirdman92 @ Apr 15 2020, 01:57 PM)
QUOTE(bbrock @ Apr 14 2020, 09:45 PM)
QUOTE(914_7T3 @ Apr 14 2020, 07:32 PM)
If you only have two tabs on the lamp then one is possibly missing or it is an incorrect replacement part. The correct one has 3 connections. Many look the same from the front.
I count 3 tabs in the picture.
Well you didn't have to cut one off just to make me look bad.
Looks like either one of the connector tabs has broken off or missing, or you have a funky 2-position switch rather than the normal 3-position. If the tab is missing, you could fashion a tab from a scrap of copper and solder it on to that pad.
You should be able to see if the switch makes contact on one side or the other as you move it each way from center.
