QUOTE(Zaffer @ Apr 16 2020, 01:30 PM)
The fan is from the 1.7L engine as the 1.8L did not come with a fan or fan housing. I marked the fan according to the flywheel and it seemed to run pretty well at these marks using the distributor with the electronic ignition in it and the carbs from the 1.7L, and I can adjust that one in pretty much any position due to not having the vacuum diaphragm. I decided to go with the factory FI as the 1.8L never ran right with the carbs and I assume it still has the FI cam in it, plus whoever did the carb "conversion" did not do a good job and the carbs kept running rich, regardless of rebuild, adjustments, etc. Come to find out, the FI fuel pump was still installed, but I didn't know this until I received the FI system.
I looked at the engine pretty closely when I received it and I can't see anywhere that it has ever been opened, but then again we are talking about a 46 year old engine. There could be other things going on as well, just would rather use the stock distributor if possible as it's in good shape.
The case does not have to be split to put in the distributor drive gear. The Haynes manual has a great description on how it should be installed.
