QUOTE(Mark Henry @ Apr 26 2020, 06:19 AM)
..I'm going to have to measure the front hubs on my '74 with the fuchs but eyeballing through the rim I think it's also 47mm.
Yes, please do check for me the next time you have wheels off, appreciated!
I imagine the 40's will work as well, just 7mm narrower on each side.
True, the 7mm is not a big deal for tire placement - BUT the thing is, only one hub (either 40mm or 47mm) is going to be the correct hubs for the Brembo cals/Vented rotors combo, specifically.
QUOTE(davep @ Apr 26 2020, 11:57 AM)
..The M calipers would have spacers between the halves to accommodate the vented rotors. I'm not certain about the hubs, but somehow I think that solid rotor had a different (thinner) hub.
Yes, like the Brembo rotors, which is why it's important that I get the right hub. So I was wondering which hubs the M rotored cars used.
QUOTE(mepstein @ Apr 26 2020, 12:00 PM)
... I did put unvented M calipers and rotors on the front of my conversion car and everything worked fine with early (non hub centric) hubs.
So, you're saying that you removed the spacers from the M calipers and used solid rotors and 36mm hubs?
